ROCKSTONE POWER 2000 Watt Voltage Converter Transformer - Heavy Duty Step Up/Down AC 110V/120V/220V/240V in S Carolina.
Shawn Hayes
Learning Everyday
In A Southerly Direction
For sale: 1- for sale, brand new in box!!
$80.00 plus shipping. Local pickup available as well.
ROCKSTONE POWER 2000 Watt Voltage Converter Transformer - Heavy Duty Step Up/Down AC 110V/120V/220V/240V Power Converter - Circuit Breaker Protection – DC 5V USB Port - CE Certified​
  • 2000 Watts Heavy Duty Step Up/Down Voltage Transformer Converter. Step Up Voltage from 110-120 Volts to 220-240 Volts. Step Down Voltage from 220-240 Volts to 110-120 Volts.
  • Patented Simultaneous 3-Mode Output: 5V USB Port / 120V USA Output Socket / 220V Universal Output Socket. CE Certified.
  • Metal Casing. Full Range Fuse Protection. Full Range Over Current Protection.
  • For safety reasons, it's recommended to use a Voltage Converter/Transformer that's max watts is at least 50% higher than your appliance. For example; 2,000 Watt transformer can be only be used with an appliance that uses up to 1,300 Watts that is to prevent damage from the transformer itself and the appliance being used.
  • Package Contents: Rockstone Power 2000 Watt Heavy Duty Voltage Transformer Converter, Hardwired Heavy Duty Insulated Power Cord with USA Grounded 3-Prong Plug, American to European Grounded Schuko Wall Outlet Plug Adapter, 2 PCS Spare Fuses, and Instruction Manual.
  • Product Dimensions 10 x 7 x 5.8 inches
  • Item model number RSP-2000
Spring cleaning here, selling things I don’t need or have extra of.
BEC141F7-493E-4814-853D-B46F2E1C596A.pngF54EE804-A064-4E70-B051-A36AFE0F864D.pngEEF1C238-2F32-4406-AC09-780388928CF3.jpeg
