rogerheflin
90%+ of those homeowners may not have a bypass switch and if they do, do not even know what/where it is and even when/how to use it.I'd say the opposite. You don't care about the homeowner who would have to just throw a bypass switch to disable it. You REALLY care about the 5% of equipment in mission-critical installations (energy, security, aviation, railroad etc) that have been firewalled to prevent you from doing just that.
firewalled mission critical typically has rules to ALLOW the devices to talk to the manufacturer in all but DOD/DOE isolated networks. I used to work in mission critical (and I have done work on NNSA DOE isolated networks) and all but the truly isolated had rules to allow their critical devices to call home to the manufacturer for the hardware (typically could not get to the data easily--but would be able to disable/turn off the hardware).
If one was to drop a decent % (say even 25-50%) of the solar off the grid at about the same time that will cause the entire grid to go into blackout. Nothing would be able to spin-up fast enough to stop all rest of the solar and the big generators from disconnecting, so you end up with a grid restart similar to what Spain had a few weeks ago.
