Graph hits bottom limit of SoC quite a bit. Does your power shut off every time that happens?
This is for a grid tied system and so when the simulated battery (and PV array) can't supply the home's demand, either because the power demand is greater than the battery can supply (e.g. a Powerwall 2 has a 5kW discharge limit) or because the battery has reached it's lower SOC limit, then power comes from the grid to make up the balance.
Just in case you didn't pick it up in my earlier post, this isn't a real Powerwall, it's a simulated Powerwall. I created a model to simulate the behaviour of a home battery based on a given battery's specs and the rules used to determine when and how charging and discharging occurs.
The data I feed the model is our actual consumption and PV array production (5-min interval data from my Fronius system). It realistically simulates the battery's impact on our grid imports and exports (obviously both are reduced) and the consequential impact on our electricity bill.
The charts I posted are for a simulated battery with the specs of a Tesla Powerwall 2 but I can input any battery spec I like, e.g. a much larger or small capacity battery, or change the charge/discharge rate, or change round trip efficiency losses (e.g. if I want to simulate a flow battery).
It's been a useful tool to assess the merits or otherwise of installing a commercial home battery system. That said, a back of the envelope assessment of battery financials using just a few basic input assumptions is usually good enough to know if a battery is going to be financially worthwhile.
I see your profile "about" says grid-tie but backup powering pool pump, so is that the only load affected?
My off-grid system is unrelated. Let me explain.
Our home has an 11kW grid tied solar PV system. We've had that on the roof coming up to three years now. So the above simulation is for our home and this grid tied system.
Recently I built an off-grid battery system to be our backup power source in case of grid outages (we get outages frequently enough to warrant backup). It's just a 48V bank of SLA batteries with a 4kW all-in-one inverter. This became an alternative and easier to use option than the Yamaha generator we have. It feeds power to the home via a power inlet and a manual transfer switch when needed. The generator is now for redundancy and coverage in case of long outages. The primary purpose of this battery is for outage backup.
To supplement and support this off-grid storage, I have just also added this past week a separate 2.2kW PV array to it (managed by the AIO inverter/charge controller). So rather than the battery being kept topped up by grid power, the solar PV array can do that duty.
But since keeping a battery bank on float doesn't use much energy, I figure I may as well use the PV array's output capacity for something useful, and so I have now swapped my pool pump over to be powered by the off-grid system. It should not draw much energy from the battery, and is instead meant to draw most of what it needs from the off-grid PV array (it operates on a timer set for a daytime duty cycle).
I describe my project and progress in this other thread:
Greetings from down under. I live in a home near the small town of Bellingen, in northern NSW, Australia. Glorious country: That's our home at left centre, and obscured by the tree and slightly off the left of the image is a secondary dwelling where my Mum lives. 12 acres, behind our home (to...
diysolarforum.com
