Pietskiet247
- Nov 14, 2021
- 4
Hi Everyone
I have a Growatt 5000ES inverter with a Rosen 200Ah Lifepo4 battery with BMS.
Rosen shared video that the battery can connect to my inverter via RS485 on setting 36 with L01.
I can only managed to get it communicate with CAN on my inverter on setting 36 with L52.
My problem that I'm facing is the BMS looses communication after or about every 24-36 hours for about 1min.
When loosing the communication the Output Voltage are lost and everything is down for that time period.
Rosen came back to me to say my Inverter have newer firmware and can't connect via RS485.
They can only support RS485 and not CAN.
Strange because I can connect via CAN but there seems to be an issue.
Anyone else have similar issue or anything suggestions I can try.
Rosen said I need to get Inverter that can communicate on RS485 or run battery with USE setting without the BMS.
If I setup the Inverter with USE2 settings the SOC is not displayed correctly on Inverter.
I would appreciate any assistance.
Thanks
Thanks
