Hello I recently purchased a 200ah Powerurus battery and it has been okay for me. However the app is very barebones and has some features that are undocumented and difficult to figure out. I have contacted Powerurus and Roypow for support, but so far their support has been very lacking.
Does anyone have any of these batteries, or similar, connected up to Home Assistant to check the data from the BMS over bluetooth? I do not have a HA system yet, but plan to build one and would like to know if this is possible before my return period has expired on the battery.
Hey I think you’re the person who wrote the top review on Amazon for the Powerurus 200Ah.
I’ve been considering this battery for some time but would love to ask you a few questions if you don’t mind.
Does the 0-100% power meter in the app base its reading from voltage or does the battery have a built in shunt to measure amps in and out?
And can you see the voltage of each cell individually or just max, min and difference?
Finally, does the “amps” measurement (which you say is always a a negative number), simply show you the sum total? Meaning if 80 amps are being discharged and 20 amps are being charged into the battery, the amps reading would be 60? Actually -60 since that pesky negative sign is stuck there.
I’ve never seen or used a lifepo4 battery or their Bluetooth app, so I’m not sure what to expect. I’ve installed various BMS apps on my phone (even though I have no batteries yet), including the Roypow Fish app. These apps allow me to see some of what info might be available but since I don’t have a battery yet it’s a bit of an estimate.
I did write Roypow via their Amazon seller account to ask if they intend to upgrade the app. I’ll update you if they write back.
