RS485 between DJB BMS and Growatt
rj86
Got a quick question, Has anyone tried to get the RS485 communications setup working between a DJB BMS and a Growatt inverter? I have an SPF 6000T DVM-MPV and a JBD-AP20S003S I ordered from Docan Power. I saw an older thread that was similar to this but it looks like it's a couple of years old. Has anyone tried this yet and if so do you have the settings to get things talking?
Correct typos in yours the text.
JBD does not communicate with Growatt after rs485 / CAN.
Buy the LCD screen for BMS JBD, it is touch-sensitive and functional. In Growatt, set up your own batteries and regulate the voltage range of the energy storage.
I bought the lcd display rs485 and it has comm error. I also tried PLY direct to lvx6048
it seemed to work for a while then a fault light but no fault code. Then inverter goes into standby mode. I do not think JBD has an address set on it needed for multi drop rs485
LCD panel settings. A and B on the panel In my case it helped and the LCD panel started to communicate with the BMS board
. JBD BMS is not communicating with Growatt. Do you know JBD BMS, his work is lame, often lost SOC, BT you know ... Even better he doesn't work with Growatt. Thanks, you can recommend Growatt with intensification.
001 SUb (Solar First + Util. First)
002 30A / 20A - dopuszczalny prąd ładowania akumulatora, a. dla ładowania z GRID ustaw prąd jaki dopuszcza instalacja baterii oraz przyłącz Inwertera. b. dla agregatu prądotwórczego STANLEY SIG2000-I ustaw wartość z przedziału 10-30A, pamiętaj aby suma obciążenia (Prąd ładowania baterii + Odbiorniki na Inwerterze) nie przekroczyła 1,7kW tj. maksymalnej mocy agregatu STANLEY SIG2000-I !
003 UPS
004 dIS
005 US2 Zauważ, że podpięta bateria to LiFePo4 w konfiguracji 16S2P. Zgodnie z instrukcją jest możliwość podpięcia tzw. własnej baterii - w nastawie nr 05 wybierasz “User-Defined" = US2. W takim trybie Inwerter nie komunikuje się z BMS i "baterią". Dla takiego ustawienia w nastawie 19, 20 i 21 musisz wprowadzić prawidłowe napięcia graniczne dla podpiętej baterii. Inwerter nie komunikuje się wtedy z BMS baterii i nie otrzymuje informacji na temat stanu akumulatora (poziom naładowania), jedyny wskaźnik to napięcie baterii. Należy zatem zwrócić uwagę jakie parametry wprowadzasz dla podpiętej w ten sposób baterii w nastawie 19, 20 i 21 - tak aby nie zniszczyć akumulatora lub nie wywołać przeładowania = pożaru.
006 ENA
007 ENA
008 230 V
009 50 Hz
010 4
011 40 A (AC Input)
012 50,2 V b2.AC
013 53,0 V AC.2b
014 SNU
015 ON
016 ON
017 ON
018 ENA
019 55.4 V (C.Y.)
020 54.0 V (FLt.Y)
021 48.0 V (Cut.Y) ....
050 00 00 (praca baterii możliwa od 00:00-00:00 = 24h)
049 11 17 (ładowanie baterii możliwe pomiędzy 11:00 a 17:00, zmień ustawienie jeżeli podpinasz agregat prądotwórczy w celu uzupełnia baterii w przypadku braku GRID)
048 OFF
JBD has a proprietary bms protocol can't talk to any inverter. You have to setup your growatt battery configuration manually.
