So, a little bit of background on me - I've done a lot of construction work over the years (put myself through college doing apartment rehab and appliance repair), and have done a number of small-fry solar installations (usually just remote 12v field site stuff done in conjunction with mesh wireless). So I'm familiar with solar and electrical principals and concepts. But - my day job was scale-out storage. So I'm used to thinking of things in terms of mean time between failure, failure points, and fault mitigation.
Which lead me down the path of a lot of googling, that unfortunately has lead me to mixed reviews. This is my first post here, and this forum seems to be the nexus for most of the subject matter expertise regarding LifePo4 battery banks out there.
I'm aiming to build a 48kwh 48v LifePo4 bank. As I see it, there are 2 high-level ways in which I can do this.
Method 1: Parallel the cells
In this method, I'd take 3 320ah 3.2v LifePo4 cells or 4 250ah 3.2v LifePo4 cells and parallel them, then connect each paralleled unit to the next, and so on.
Cons:
- Would require higher amperage bus bars
- In the event of any failure of any individual cell, the lifetime of the other two to three cells in parallel would be shortened due to depth of discharge increasing for the other cells in parallel
Pros:
- Single BMS
- Failure of any single cell would result in higher draw on cells in parallel, but would not result in substantial loss of capacity for the bank (discharge, yes, capacity, no)
Method 2: Parallel the strings
In this method, take 16 320ah 3.2v LifePo4 cells and string them together. Do that with three strings. Parallel the strings
Cons:
- Any fault in any individual cell will effectively take the string offline due to voltage drop
- Would require multiple BMS
Pros:
- Can readily identify faulted cell (in paralleled cells, you can identify quickly which set of cells are faulted, but not the individual cell)
- Because of how the faulting is handled (namely whole string goes offline), no long-term damage to the string. Swap out cell, back online
- Higher voltage / less amperage = fewer bus bars
You can mix and match as well, of course. Build a few 12v strings, parallel those, then link them to create a 48v string. Etc.
I've searched a long time to determine what the best practice here is - good chance this has been discussed elsewhere and I'm using the wrong search terms. Anyone have any recommendations as to best practices here?
Cons:
Pros:
- Single BMS
Cons:
Pros:
