Sundog33
Sun Bather
So, how to deal with 12v loads when LITHIUM Battery voltage can theoretically go up to 14.6 volts?
I like to use as much straight 12v things as possible, I'm sure lights and Fans would run over 14v,
but most likely be brighter and faster and have shorter life.
I used to use a DROK step down regulator on my old AGM System. But it was only good up to 3 amps.
and I just read that buck converters don't really work in this scenario anyway? Is there a magic bullet for regulated 12v?
I see Will talk about being pleased that some ALL-IN-ONE units have regulated 12v outlets. How to accomplish
that on your own? Really Victron should be regulating the Load voltage from the Charger, but I'm not seeing that.
Unless I just didn't go up high enough yet to notice.
Thanks
Thanks
