Hiker
Rather than using a cigarette lighter type plug to charge an Ecoflow, I'd like to run a dedicated circuit with a switch and replay. I'll be using 12 awg for the power from the battery with a 12 awg 30 amp inline fuse to a 4 pin 40/30 amp relay with a switch spliced from an ignition-on wire. The power wire will have a XT60 connector to fit the Ecoflow.
The Ecoflow car charger supports 12 VDC, 8 amps. The length of the wire will be around 10-12'
Are these specs going to be OK?
It seems like most relays found in parts stores and Amazon are similar to the one I'll be using
