Rokkerhead
I’m planning the installation of a 12000xp with 2 indoor wall mount batteries. The total height of the inverter, battery and conduit box is about 80”. Unfortunately, my basement has a ceiling height of about 85”. Therefore I won’t have the required 19.5” clearance above the inverter.
I’m going to have to mount the inverter lower on the wall while having the batteries off to the side.
What would be the best way to run the battery cables to the inverter? The bottom inputs of the inverter will be lower than the top of the batteries. What kind of conduit would best suit this install? Is it correct that the paralleling cables need to be the same length as the battery cables going to the inverter?
