Will,
I've watched so many of your videos, really enjoy them! I especially like the testing you do on batteries so that now I've just ordered my first LifePO4 12Vdc 200Ah battery.
But I'm confused by the solar systems you setup in that they don't explicitly incorporate all the power systems on my RV. I have a 12Vdc system and 120Vac system and I understand how to connect the solar system to those, mostly. But when it comes to the solar controller to charge the battery, how do I connect all the other power systems?
For instance, when on shore power, there is a 12Vdc battery charger. When I'm connected to my truck there is my 12Vdc system from the vehicle that charges my RV batteries. How do all these charging systems get incorporated with the solar system that I want to install on my RV?
The reason I want the solar system is that my RV has an efficient 120Vac refrigerator that works on the 12Vdc system via a 1K inverter (pulls 315 watts). But it can only run for 4 hours on the current lead acid batteries. So I want a better battery and solar to keep them topped off and be able to run the refrigerator all day and maybe into the evening if boondocking/dry camping.
I don't want to hurt the new LifePO4 battery I have coming with a small 360W solar panel/system that I want to be able to expand at a later time. I was going to use the Victron MPPT 30A on your website but don't see how to connect it with all the other 12Vdc systems mentioned.
Do you have a video that takes all the individual 12Vdc systems and connect them all together? It needs to work under these conditions:
1. Boondocking/dry camping - allow for running generator as needed.
2. Towing - charge batteries off tow vehicle 12Vdc system
3. Shore power - maintain 12Vdc system while connected to external power.
4. Generator running - all add separately but used when dry camping.
Again, thanks for your videos and website, but I just need these diverse systems added to the solar system equation!
