Rv converter/charger
Ronwattson
Southern Ga USA
Thinking of just installing one of these in my solar shed for back up. Anyone use these for that purpose other than for an RV?
Vevor is just a "re-brander". They don't make anything. @Rednecktek recently identified a brand on Amazon that's similarly priced and seems to be well regarded. Hopefully, he'll poke his head in there and comment.
I use a Powermax PM4-100LK for a very non-standard purpose and am very happy with it.
Worth noting that most ratings are for a lower voltage than typical bulk/absorption charging. They tend to only deliver their max current at lower voltage. If you actually want 80A through the bulk phase, you should be looking at a 100A unit.
T
Thank you sir! Have a transfer switch that is grid tided but I also like the idea that if my bank needs to get by a day or two with a little help at night with this to get to sunny again just use this instead. Also it seemed like a cheap way to supplement charge if needed while running a small load.
T
I have mine on a smart plug where I can turn it on/off remotely manually, on a schedule or simply start it and set a shutoff timer.
@ sunshine_eggo, I am thinking about adding one of the powermax 100a chargers to my motorhame and have a few questions. I have 920Ah of LFP installed and charge it with a Magnum MS2012 invertor charger. It will output 108A charging and the BMK battery monitor shows that from 80A to 90A reaches the battery. When dry camping, I need to do all of my charging form the 10kw generator and only 80-90 amp charge takes a long time. I want to add a second bulk charger which will be connected only to the generator output so that it will only work when on generator.
  • Do you have any info on the actual amps that it will deliver to a largeish FLP bank during a say 3-hour run?
  • Can you adjust the output voltage on the unit?
100A at lower voltage. At bulk voltage, about 85A
The "LK" units can be selected to operate as charger or power supply with the bulk/power supply voltage pot adjustable.
