frzbgolfer
I have a fifth wheel camper that I swapped to a 12V 230AH LiTime Lithium battery last year. I had also replaced the converter with one that is compatible with Lithium (well it is an auto detect model that seems to not want to detect that the battery is Lithium but that is a topic for another day). Everything has been working great for the past year. I acquired a new 1500W inverter for free so decided I wanted to add that into my system. So I add that along with a QWork battery monitor system. Oh and I added an automatic transfer switch to switch between shore power and inverter power. Testing went fine other than the inverter not being able to do anything close to a 1500W load but other than that everything was fine. After depleting my battery, I turned the inverter off, plugged my camper back into shore power, and turned the breaker back on to my converter to start charging the battery. Initially I could see via the battery monitor display that the converter was sending around 50 amps to the battery. I noticed it fluctuated some but figured that was normal. I let it be for a bit and when I checked an hour or 2 later, it showed that it was no longer sending any amps to the battery. It had only pushed around 2.5ah total to the battery. I tried turning the converter off and back on but that didn't help.
Here we are a few days later and I had time to do more testing. Using a multimeter I was able to see that when I turn on the converter, it is sending around 13.7V but the battery monitor showed no amps going to the battery. I disconnected the battery and checked voltage, it was around 12.2V or thereabouts. I checked all connections and verified continuity between the converter and the battery on both the positive and negative sides. Hooked the battery back up and tested again, no change. I then took a 12V battery charger I have and connected it to the battery (well I put the negative lead on the load side of the shunt so I could verify the amperage going into the battery); the charger was sending 14-15 amps to the battery which is the highest that charger can do.
So would all these things point to an issue with the RV's converter? What other testing can I do? Oh I also checked all the fuses on the RV's DC panel, all are fine. Thank you to those who took the time to read through all of this. I tried to keep it as short as possible but still giving all of the pertinent information. Let me know if you have any questions. THANK YOU!
