Looking to convert house batteries to 280ah LiFePO4 cells. I was hoping to get some advice to make sure I don’t miss something in the conversion. Currently have 6 - 12v AGM’s. The RV has a full size all electric residential fridge. I’ve installed about 1400 watts of solar on the roof.
1. Any possibility of damaging the alternator? (2017 Cummins Diesel)
A. Have read the alternator can get damaged running lithium cells. Is this true with the new 280ah cells?
If so best way to prevent damage.
2. Batteries are charged 3 ways - Shore power (Magnum 2800 watt Inverter), Victron solar charger, and engine alternator.
A. Will the batteries get overcharged by the alternator or will the bms prevent this?
3. Any other tips would be appreciated.
Thank you!
Thank you!
