So
@grizzzman or anyone else, then could a LFP be used as a "trickle charger" for a starting battery during storage?
I have a 12v 304Ah LFP and am wondering if that could be a way to maintain my RV starting battery. I would only hook the charged LFP up to the starting battery when storing (never when the engine is on). It would be isolated from the house and 24V battery systems.
Appears so. By voltage, it appears you could connect them at any state of charge as long as LFP voltage > starter voltage. The danger appears to be rate at which LFP accepts charge, but that won't happen from a standing lead acid battery with its lower voltage even when fully charged. Or the rate at which LFP can discharge current, but that won't happen either due to internal resistance of lead acid battery. But I can only repeat what I've read.
Maybe ask this guy on youtube. He'd probably rig it up to see. Batteries that refuse to explode were made for him.
The charging ( mostly solar ) is set up for 14.2/13.6 (float well pass though ) as well as the mains charger.
My boat presently has a lead acid starter battery, two 6v FLA trojan T-105s in series for a 225Ah house bank, and another lead acid in the forepeak for the windlass. Perkins 4108 diesel and a 100amp internally regulated alternator. I began a week or so ago thinking I'd just hang one or two LFP 100Ah batteries off the house using Clark's bank manager.
But then the issue of overdrawing the alternator came up. I should also say my first trip will be motoring 1300nm up the Atlantic coast in a "new to me" boat, and so am hording cash for the unexpected rather than extensively upgrading components.
Clark has a video on modifying a stock alternator which I've watched more than once. The discussion of the modification is described in 1 or 2 sentences and is over in about 10 seconds. I probably shouldn't dive into it, since the timing before the trip and margin for error is slim. Prior owner cruised the boat all over the caribbean extensively, including motoring for days between the Mexico, Belize and the US. The systems, as is, should get me home. Just need some extra capacity for laptop / internet and remote employment while making it home.
The next idea was the internally regulated alternator into the lead acid starter battery, and from there the less expensive renogy DC-DC charger into a new lithium house bank and bypass the 6v FLAs.
Now, I'm thinking they can be used. Alternator into starter, with DC-DC to a busbar with the two 6v FLA in series and new LFP connected in parallel directly - never to come apart. Clark's idea is overly complex, as long as the charging sources into the hybrid bank are set to lithium charging profiles.
On that note, I'll post the video I wanted to share. Did you see Rod Collins "15 year old lithium battery update"?
Minute 9:45 -18:00 or so. He charges to 13.8v at .4C, holds for 1 hour of absorption. And floats at 13.5, sometimes. Other times, no float.
