I have a 2021 Airstream 27' travel trailer.
I would like to install "The classic 400 watt solar package" in/ on the trailer.
I'm planning on using the Rich solar 60 amp mppt charge controller as I want to have the ability to use a 200 watt solar suitcase as needed.
I have 2- 100 amp hour lithium batteries. From there go to a 3000 watt , 12v Renogy pure sine inverter.
From there I would like to go, hard wired, into a 50 amp automatic transfer switch (trailer uses 50 amp shore power) to feed my built in distribution center.
I know I will have to disconnect the existing on board Converter/Charger
Any advise on any of the above would be appreciated
But my question is about a A/C to D/C charger wired out of the transfer switch to charge batteries when connected to shore power.
Is this possible?
Any advise on this?
Simular to attached illustration
Is this possible?
Any advise on this?
