We purchased a new towable rv trailer that has a built in Generator and 200 watt solar panels on the roof with a go power controller. I want to upgrade my batteries to lithium but I’ve since learned that the built in inverter charger need to be upgraded to support lithium charging it will only provide 85% of a charge. I also realized that lithium batteries will not turn my generator over.
Any suggestions? Should I just go back to led acid?
I only got a 2 years of life out of my led acid batteries. Either over charged or under charged. I noticed that my inverter fan runs all the time if I’m on shore power and have the battery disconnect switch on to maintain the battery. If I turn the battery disconnect off the batteries are always dead when I need battery power.
