This is what I do. Charging at about 12 amps for 3 hours using the AIMS charger I get 50%->80% (30% change) SOC on my shunt monitor. I use a cheap mechanical timer and it works well. If you get smart timer you could trigger it remotely and have it charge the night before you mow when the battery temp is in the ideal range. (in the SE USA night would be coolest 65-70F).Best way to hit 80% SoC is charge into knee of the curve, then discharge 20 Ah.
If you measure how many Ah consumed running the mower, you know SoC. Then recharge with a CV/CC charger on a timer to reach the SoC you want.
Looks great! The cable management is way better than how mine turned out.Another RM480e conversion thanks to the pioneering work of so many of you.
New EVE 105ah cells from 18650batterystore.com, delivered quickly and were packaged well. All 16 arrived at exactly the same voltage, delta of .001.
Overkill BMS
Cheap 12a Lifepo4 charger from eBay.
Put the charger in the battery box I built, not using the built in charging port. Didn’t mess with the gauge as it never worked anyways and I just monitor the battery from my phone now.
Runs great, can easily do our whole property where the agm’s could only do a quarter at a time.
Well done.Another RM480e conversion thanks to the pioneering work of so many of you.
Overkill BMS
I joined this forum just for this thread, I bought my ryobi 2 years ago and the batteries are shot, can barely mow for 5 min and it stops cutting now.
I need to get it working ASAP. My plan is to get drop in replacements but i am new to all this, and ive read and reread through this and am very nervous about trying to do this myself. These are the batteries i am looking at (https://www.amazon.com/gp/product/B099FB9PQ4/ref=ox_sc_act_title_2?smid=A138YWHSOUG8CW&th=1)
I think they are just about the same size as the oem batteries. What else will i need to get my mower running again any help will be greatly appreciated
Ideally you might want a 4-bank charger so that you can charge each battery independently, but that adds an extra burden in charge logistics.
I can easily maintain my SoC very comfortably between 20% and 80%. Knowing that the Delta-Q charges at 14 A, I can just set a timer when I'm charging and unplug. To account for drift in the Ah measurements (both in the shunt and in the Overkill BMS), I "top it off" once every month or two: let it charge to about 3.5V (above the knee for my cells) and reset the Ah counter to 100%. When I do this I keep a close eye on the app, and the Overkill always cuts charging the instant one cell hits 3.5V.
Like others, I joined the thread specifically for this and don’t have experience so am looking to use four 12v drop ins (ampere time). I’m too worried about screwing something up in a battery build and blowing everything up haha. I’d love to get away with the oem delta-q charger, but also share the concerns there, especially after some of these latest comments since idk if I can trust the bms in those batteries, and wouldn’t have any app that could help me keep on top of things.
Would anyone know if it’s possible/ how to splice/connect the triangle shaped plug from the delta q charger to a 48v lifepo4 charger (aims or other via Amazon)? I think dochoot went this route but i don’t think he’s said how it’s been working out. How many amps should I look for in a charger? I know rio said earlier no more than 15a, others had issues with lower amp chargers. Any other recommendations there would be super helpful. I don’t want to completely ruin the lifepo4’s with bad charging practices. Thanks to all on this amazing thread!!
Can take some pics if anyone's interested in anything specific. Figured there's plenty of pics of most of the steps I took, exception being how I secured the battery.@Jakeman that's great! Got pictures?
I'm a bit confused about the monitor initially showing low charge. This monitor has no way to know state of charge if it's not calibrated. Usually you would have to fully charge the batteries first, then set the monitor to 100%. Then after that the monitor would estimate state of charge based on measured current (discharge / charge) over time. Charging for 8 hours at 13.5A would have supplied over 100Ah - so probably overcharge protection in BMS tripped (not a bad thing). If I were you I would call that 100% and then only charge to about 90% from then on.
I would say you're probably fine with the Ryobi charger, especially if you time the charge cycles properly to stay below 90% or 85% SoC.. You can do that easily by taking note of the total Ahs used during mowing. That said, without being able to monitor the BMS you may want the piece of mind to protect your investment with a lower-voltage LiFePO charger.
You mention going with a lower voltage charger, I see that many are 58.4v and a few are 54.6v. Do you think 58.4 is too high?AFAIK, errors accumulate via coulomb counting via self discharge and accuracy of the measurement device. If you coulomb count only, it needs to be "reset" with some kind of "full charge" occasionally or you may run out of juice prematurely depending upon your usage / low Ah number to charge, and guarantee BMS re-balancing (am I right? depends upon the BMS implementation?).
Went with a LiFePO4 48V 16S charger to bypass the timing thing, but in retrospect should have gone with a slightly lower voltage charger but that's minor. I'll probably do a full charge maybe every 3-4 mowings and top balance the 12V batteries once a year. These batteries aren't being asked to do a lot. Was going to throw in some diodes in the 16S charger, but didn't care enough...
That's right at the upper end of a safe LiFePO4 voltage at 3.65 V/cell (assuming the battery is a 16S configuration).Do you think 58.4 is too high?
