Like many people here I joined the site for this very topic. So thanks again for AMDPower kicking off this question and the work of the other contributors such as Ultrasoundjelly, Rio, bobbie_ohio, Jakeman, and others. The battery issue was top of my mind back in 2020 when deciding to go with an electric riding mower with limited options on the market at that time. I certainly had the concerns with the Ryobi RY48ZTR100 using the SLA batteries vs lithium, and my real world use mirrors others like the horrible meter never reading corrrectly and shorter runtime. However, I figured I could buy and replace the Ryobi twice over before I was even at the starter price of something lithum from Greenworks or the uber pricey Green Machine. It is great to see Ryobi and other manufacturers switching over to lithium solutions, but it looks like most have taken the same path as their power tools using proprietary battery packs vs drop-in form factors. Of course I can appreciate the flip side that forcing use of their own packs helps control standards and matching battery specs. Pros and cons I guess. Fortunately, I was able to get about 2 years of cuts out of the original batteries here in the hot Florida summers which is not to kind on any battery, but at least I don't have the freezing temps to deal with.
I have about another 9 months of warranty on the mower, but I don't really have the means to easily take it to a Ryobi repair shop if something breaks which sorta makes that pointless. I am likewise done with the junk SLA batteries. However, like many here I'm not looking to get deep into building my own packs vs leveraging the least intrusive drop-in solution in case I need to "rollback" to the SLA config if I need to sell the unit for some reason.
I already picked up the Camway meter to attach. I am likely to go with the latest 12v 100Ah Ampere Time batteries off of amazon even though the CHINS seems to be basically built about the same.
Where I ran afoul is making a bad decision to use a variable voltage Beleeb charger from Amazon (
link) which said it would work with SLA/AGM and LiFePo4. I had the idea that I may be able to restore the batteries for more life, and if not have a flexible unit to charge and balance new LiFePo4 drop-ins. Unfortunately there is nothing that you set on the charger to distiguish the charging profiles and I doubt it works like they say for Lithium. However, it may not be any worse than trying to use the Delta-Q SC-48 charger that came with the mower.
The second problem was that I also purchased Beleeb's Ezgo tri pin connector to use with their charger thinking that I could reuse the mower charge port without cutting off and splicing my original charge cable (again for warranty/resell related issues). I knew I would have to bypass the lockout switch at some point for easy hookup to a charger. Well being a dummy I hooked up the Beleeb connector and no charge light indicators showed up. I plugged in my original SC-48 connector and the charge port LED lights up. I retry the connection on the Beleeb and nothing happens. I'm figuring it is the lack of the lockout pin being active preventing the LED from lighting. I retry the SC-48 and now nothing works there either. The mower won't even turn on now. No clicks or "thuds" from the lockout relay either. Again, this is just with the SLA batteries installed. Last night I checked the wiring of both charger plugs and discovered that the Beleeb pos and neg wiring are actually reversed polarity from the actual ezgo charger wiring on the original SC-48 charger. So I'm not sure if I shorted the charger, the batteries, or something else. It could also be that the old SLA batteries (which were run down anyways after my last mow) have now dropped below adequate charge which is why nothing lights up on the SC-48 anymore. More troubleshooting and testing on the electrical before I invest in modding the mower and investing in batteries. I'm going to use the electrical system troubleshooting guide kindly posted earlier on the thread.
My questions to the group are now the following:
1. Does anyone have any clear pictures of how they wired/connected the lockout wire to the positive terminal (I'm assuming the lead pos terminal was used)? I'm assuming that only the blue wire needs to be cut from the old tri-pin charge connector, a 5/16" ring crimped and attached to the terminal is the suggested approach? I see this being discussed but don't see any pictures, especially from the folks that did the drop-on approach. This of course assumes that down the road I just want to use a properly wired EZGo plug from a new LifePo charger to the existing mower charge port.
2. If I don't bypass the the lockout pin, has anyone found and used a 48v lifepo4 charger with an ezgo tripin connector? I have found a couple of products out there that have done this for golf carts but they seem really expensive.
3. If I don't want to bypass the lockout but still want to use a lifepo4 charger, it seems like the working solution is to wire everything the same as it came from the factory, but charging would require lifting the seat, disconnecting the anderson plug from the mower charger port and then connecting battery anderson plug to an anderson connection coming directly from my lifepo charger. Certainly not as elegant as USJ's 3D printed adapter, but seems the most practical.
4. All the notes I have seen said to not use the orignal SLA SC-48 charger and rely on the BMS. While the original charger approach seems to work for many here without issues that over time it will degrade the LiFePo4. Has anyone using the original charger with drop-in approach seen any degrading issues with their LiFePo batteries using this most simple approach?
Sorry for the length. Insights are appreciated. Trying to move forward one way or another since my mower is now 100% out of commission which is going to make mowing a real beast the more time that passes.
