I built my first lifepo battery last year. It's a 12 V 280 ah lifepo with JBD 120 amp bms. It's functioning well, but I have a need for a larger amp draw in my small RV. I have upgraded to the 200 amp version and have a couple of questions related to the install.
Bill
- Can I reuse the balance leads from the 120 amp model? I'd like to keep as much of my build intact as possible, and simply plugging in the existing balance leads into the new bms would be great. The new balance leads appear identical.
- Can I also just plug in the older bluetooth into the new 200 amp bms? Again, the new one appears identical.
- Finally, will the software(iOS) read the new parameters of the 200 amp bms, or will I need to adjust the settings in config?
Bill
