Thanks to
@timselectric I was able to utilize my system safely with this $550 15 k isolation Transformer. I have three us 5000es inverters in parallel. I will be coming from the grid with 3 50 amp Breakers feeding my three inverters. The two hots for each inverter will go into my AC out panel. From there I will have 3 30 amp Breakers. My two Hots from my AC out panel run into my Transformer. From the Transformer I will power my loads panel. The ground will follow from the grid hit the inverters AC out panel to the Transformer out to the load panel. I will then bond my neutral"created by isolation transformer" and ground in my loads panel.
I did away with the auto Transformer because unfortunately it is not easily if at all possible to Incorporate safely into my system.
Again Big shout out to
@timselectric
I know that my situation will not work for everybody as every system is set up differently. I will be creating a video with details on connecting everything. I hope this helps.
Signature solar has been great with providing quality solar equipment. Their technical department was superb. I was able to get ahold of them quickly. The few questions I asked them they were able to answer quickly and we're very knowledgeable on these units.
Now the grid tie safety issues:
Every situation is different. Mine I was able to figure out everything except for the auto Transformer creating a ground Loop and putting everything that walked across my front yard Barefoot at risk. Luckily I had a helping hand in this forum. I was able to read up on other peoples situations and get ideas. For me doing away with the auto Transformer end picking up a used"new" 15k isolation Transformer for $550 was a perfect fix for my system.
Signature solar sales Quality Equipment at a great price. They actually go above and beyond and help do-it-yourselfers like everybody here. The fact that they do not have a solution to every single issue for every single situation is very understandable. They are actually sticking their necks out and helping us. Thanks signature solar.
