solarfather
- Apr 28, 2020
- 38
Hello,
I have a MPP Solar 800W SCC and Two 250W Santan Solar Panels. Specs for all below.
Goals: 1) Reduce home electricity usage during the day and 2) Have a grid down backup for day use
Problem: I need a battery so the system can work (it seems the 800W MPP solar requires a battery), I don't intent to run off the battery for power reserve if can be avoided, will be relying on the auto transfer switch to grid power when solar doesn't have enough power to keep the freezer going (sun down).
*In the 1% case where grid is down, I'm ok just using the solar during the day when sun is out for now. I may have other devices on the MPP solar, of course limiting to less than 800W.
Thoughts?
Thanks
Current System:
MPP Solar:
Electrical Specifications
Continuous Output 800W
Surge Rating 5 seconds max, 2X
Input Power Factor 0.8
Input Voltage Range 90~280VAC (Appliance mode), 170~280VAC (UPS mode)
Input/Output Frequency 50Hz / 60Hz
Output Voltage 230VAC±5%
Output Waveform Pure Sine Wave
Output Regulation < 3% RMS for battery voltage range
Peak Efficiency 90%
Nominal DC Voltage 12V
Max DC Voltage 15.5V
Transfer Time (2 Modes) <10ms (UPS mode), <20ms (Appliance mode)**
Charging Mode 3-stage
Bulk Voltage (Flooded, AMG/GEL) 14.6V/14.1V
Float Voltage 13.5V
Max AC Charging Current 20A
No Load Power Consumption <15W
Power Saving Consumption <5W
Solar Charger
Max PV Input / Output 500W
Max Charging Current 40A
Max PV Input Voc, MPPT Range 102V,15V~80V
Algorithm MPPT
Specs for Solar Panels (I have multiple but will use just 2 for this setup):
Specifications:
Rated Power: 250W
Open circuit voltage (VOC): 37.6 V
Max power voltage (VMP): 30.3 V
Short circuit current (ISC): 8.85 A
Max power current: 8.27 A
Power Tolerance 0/+3%
Maximum system voltage: 600V (UL)
Fuse Rating: 15 A
Thoughts?
Thanks
Current System:
MPP Solar:
Peak Efficiency 90%
Float Voltage 13.5V
Solar Charger
Algorithm MPPT
Specifications:
Rated Power: 250W
Fuse Rating: 15 A
