luisma911
I have a set up coming up with 2x 100Ah 48v batteries with 100Ah BMS and a 12000K inverter Sunsmart LVM12K from PowMR.
My inverter max input from the battery side is 270A
How many fuses should i put to avoid fire hazard and what capacity fuses and where on the diagram.
What cable size should i use between batteries and from batteries to busbar? and from busbar to Inverter.
NO Solar panels currently connected just grid to charge batteries and use as power back up.
Batteries: https://www.amazon.com/VATRER-POWER-LiFePO4-Lifetime-Off-Grid/dp/B0CWXMNV3Y/ref=sr_1_4?crid=2PID2DWHHLX6E&dib=eyJ2IjoiMSJ9.dEkDA9EeOGaVHI6cxKdTS2vn1JPAwKGjwFUBHdxpjZ2vFielmrAUSEwS9wesmRAo2ThcwVVa26nyROLacjUPmmljWxNyFXEkawHYoSmJ-_1wp1FAp4NL6PKEIISXvJ0qev3kNOxMf76358c8gX5RUKb214EvQCL6EOi2qSlrVKIGITL2AnaUmu9KhJCpWUvJUmviaA12vnokbkAJdtaNAx4WOgJ7j8u9iAWjiIpR4MY.M_fR8g9C7YVFWf4qSFzBzmJTXDlLyP___Vj5NnFivWI&dib_tag=se&keywords=varter+batteries+48v+100aH&qid=1761406973&sprefix=varter+batteries+48v+100ah,aps,136&sr=8-4&th=1
Current Set up idea:
Battery to Battery parallel cable 6 AWG wire.
Positive side ++ 2x Batteries in parallel (100ah 48v) + (Each one with a 125A terminal fuse) + Cable( 2/0 AWG) + (Buss bar rated at 300-600A)+Cable( 2/0 AWG) + (300A T fuse)+ (inverter 12000k with max BAT Input of 270A)
Negative side -- Cable( 2/0 AWG) - (Buss bar rated at 300-600A) - Cable( 2/0 AWG) - (Inverter 12000k with max BAT Input of 270A)
Please let me know if there is a safer set up. Thank you
