Thanks for the reply!
Thanks for the comments and suggestions, they will make a better system
1. Originally, I was thinking the panels would be in series, two on the right front of the rig, close to the edge and then two in series on the left side, and then connect in parallel before going to the SCC. The thinking was that if there was shading on one side of the rig, that the may not be shading on the other and the output voltage from at least two of the panel would be at least above 17 V for SOME charging to happen. Does that make sense??
2. Good idea, I'll see what I can find for dual pole DC breakers.
3. A breaker is a good idea. I've used a fuse in a previous rig, and it was a pain to disengage.
4. The thought is that the converter (that I just bought to charge Lithium's) would only turn on when the shore power is connected and not in the circuit when the inverter is on. I would rewire the auto xfer switch so that the power would be applied to the converter only when on shore power. The Victron charger is there only because of voltage drops observed from converter to batteries that the charger will overcome. The Victron charger would be connected when the generator is attached or I ran an extension cord from another outlet to the charger. Plus I spent the money on the converter and won't get the same money back if I sell it.
5. Good point. I won't be a significant distance to the inverter. I have been puzzling over the correct amperage fuse to put in place to the converter though.
6. At the moment I'm planning on using a Blue Seas mini 6010 that specs at 300 amps. I'm all for other recommendations, because that was one of the first I found.
7. The AC loads will be less than 20 minutes a day microwave use and less than 10 minutes a day coffee maker. That's about it. everything else either can run on DC, or has a smaller inverter directly to them, like TV/DVD/Sound bar is on one 700W inverter that can be turned off. The sleep number bed controller is on a 300W inverter that can be turned off. I downloaded an energy audit excel form and put in watts and period of use. The result of lights and AC use was 2 days of useable power in the batteries if I didn't charge at all. Until I can budget for the solar panels, I'll be charging with a 2000W Honda generator periodically on days I don't have shore power.
Thanks again for ideas and comments. I'm hoping the information I put as a response doesn't look like I'm arguing with you, only explaining my thoughts behind what I put in the drawing.
It looks like with some minor changes to components and wire gauges, the system might work, safely?
