roly1
I have just received my first shipment of LiFePO4 cells to update my bank.
They seem to spec with a 0.002 max difference in voltage.
They are CALB 230Ahr contained in an aluminium case covered in thin plastic
insulator with rather large aluminium terminals lasered to a flat round terminal stud from battery.
I am concerned that insulation between the square terminal (-ve) and the aluminum case is <1mm thick plastic and could imagine it could easily be a point of failure.
The AL case seems to have positive polarity relative the negative terminal and voltage same as battery. Is this normal; seems like this is not right to me?
I'm tempted to run a 50ohm resistor from case to negative and measure the current.
Even if it is not capable of moving significant current, the prospect of leakage doesn't thrill me.
Edit: On a search I found this is is normal MO for LiFePO4. Not what I would have expected!
I will be doing a rather elaborate insulating FG pouch for each cell and maybe a supa sealant under the
edge of each cell neg terminal. (Or try an swap out for plastic cases with the vendor)
Plus an enclosure to keep out sea elements.
