Merl Priester
- Dec 19, 2020
- 14
I am wanting to install this in a travel trailer to the main breaker panel. I am planning on using an automatic switch (go power ts-30).
It has a 30 amp service. I understand that the UL458 standard calls for the neutral and ground to bond when off grid, But does this mean the neutral is a true 0 volts or am I going to get 60v on the neutral-ground and 60v on the hot leg. I cannot find if this unit has a true 120 v hot and 0v neutral.
If I cannot do this trough the panel I will wire the microwave direct to the inverter. I only really needed the micro anyway but I did want the outlets hot also.
Thanks for any experience on this. Not wanting to fry anyone on an unsafe grounding situation.
