Smokin
- Sep 8, 2021
- 217
The Idea is to get a Tub and put sand in like 4 inches and place the 300ah cells evenly spaced and pack sand around them and use cables "NOT BARS" and hook and then put a layer of sand on top. This sand should be clean like Play Sand you can get. The Batteries go outside and a Water systen can be employed to cool the pack when it goes exothermal . Need a vent stack. to vent the smoke. Someone should test this concept on LMC cells. YEAH?????..
I think if you burn a standard cell under sand the danger will be reduced to a managable level. Except for the fumes.
