Where did you guys learn about the MC4 connectors , brands, tools, wiring, etc to get these panels wires. I recieved half a dozen for my RV today. Sending 50 more home
I forgot to research wiring. I'm going to go to a midnight solar combiner box then to my controllers. I though why not make my own cables to make wires shorter and less sloppy.
MC connectors are great to work with, touch-safe when dealing with high-voltage strings. Waterproof.
I just buy ready-made cables, cut them in half to make pigtails and feed the bare ends into combiner.
Put a pair of these pigtails on single panel to check polarity and color-code. That way you get polarity correct.
If cables are too long just coil up and cable tie out of the way. No reason to mess with cutting, splicing, or installing new connectors.
If you want, make custom length extension cables. But don't cut the ones that come on panels.
I may buy bulk materials for for the 15 pairs of pigtails and 15 extension cables I'm going to need, due to cost. Simply because the assembled cables I'm seeing today cost more than the last batch I bought.
Should I buy santan MC4 connectors and PV wire?
There or elsewhere. I got some from an eBay vendor.
You'll need a crimper for the connector size. Make sure everything is same wire gauge.
There appear to be a couple styles of locking shells. Some you can sort of open with fingers, or with a tool. Some have the locks shrouded and not all tools work.
