Ok so I’m planning a new build, will be approx 2800 sqft metal building with infloor radiant slab heating. Will be using an outdoor wood boiler for heating floor and domestic hot water. I currently have a 5.4kw solar grind tie in setup but use a 50kbtu instant boiler for my radiant heat so huge electrical useage! In saying that when not running the heat im using 330ish kwh per month, so that would be my similar load for the new house maybe less as everything will be LED etc.
So my question i guess would be what size battery bank would be ideal for my use? Been reading lots on those lifep04 banks. But not sure if 48v or 24v is what i should run. Will have to do solar maybe 20 of those 330v panels from Canadian Solar. Then a heavy duty inverter and charge controller would be needed?
Im leaning towards an off the grid setup because the new property currently has no power and its $30k for a transformer to be run to the property plus hook up to the panel.
Was thinking i could build an off grid setup for less then that and not be a slave to the power company.
