brandnewb
Going for serious. starting as newb
arggggg. even though having set the SPS to 3.6V I wake up today to find my cell charged to 3.74V it's not screwed now is it?
Patience grasshopper.arggggg
You know me a bit by now ;( of course I did not ;(Did you verify the supply with a multi-meter before connecting?
wise words indeed.It is more often than not, the Most Painful / Expensive lessons are what it takes to Learn before leaping. Most of us burn our hands on the stove only ONCE but a few have to do it 2 or even 3 times before getting it. There have been Many Years of Experience & Lessons learned (all at great expense too) shared on here.
Impatience, the Instant Rice Society Metality IS NOT for THIS ! Patience is a requirement along with Due Diligence.
@3.74 there is No Damage BUT get it down to below 3.650 quickly, it will self discharge anyway but may take time and that's not good.
Always PRESET the voltage at the connectors BEFORE attaching to cells (single or string) for Top Balancing.
I mean going to 0 for once can't hurt too bad can it?
Yup it's confirmed now. The tester got accidentally disconnected but went on after reconnecting. So I figured to also change the connectors.Depends on where you measure. You probably have a large voltage drop over the cables and because of those alligator clips.
Non mobile of course. I have no plans to power my premises with engine like loads powerful like an EV vehicle.Is there a real world use case in where that is needed?
I meant, although EV engines are cool!! they are nothing insane yet (yes gang here I go again )loads powerful like an EV vehicle.
30 seconds on Google will answer that for you.Is there a real world use case in where that is needed?
Please NO30 seconds on Google will answer that for you.
