mrzed001
Voice of reason
I did find a 3 phase inverter though with all the EU credentials and a standard 10 years of warranty that seem to not accept any less than 106v battery
Sure it is a Chinese brand with many aliexzpress counterfeit crap. But they do seem legit from the sources I am looking at.Growatt SPA4000-10000TL3 BH - Residential Storage Inverters - Growatt
Growatt SPA4000-10000TL3 BHhouse inverters,three phase inverters,solar system invertergrowattinverters.com
Even a well known professional dealer sells them.
Can one think of additional reasons not to go 48V+?
For HighVdc batteries usually the charger is not part of the inverter, but the battery !
Like with the LG RESU 10H
So the battery system gets "something" from the inverter and its DC/DC Buck/Boost converter transfers it to charge voltage.
Also regulates it for CC-CV charging.
And the same Buck/Boost converter transforms the battery real (like 2x48V) voltage to the high DC voltage.
Usually the battery is directly connected inside the inverter ... like a solar string.
You can use this 3 phase (real) hybrid inverters also.
They have all the needed EU certificates, and use (also DiY) 48V battery:
- Voltronic Infinisolar 10kW (aka MPP Solar MPI 10kW) inverter, 1-3 year warranty, produced almost a decade long.
- Deye 8-10-12kW inverter, 5 year warranty, can even run other Grid-Tie inverters AC coupled. Top seller in the US (there called: Sol-Ark)
