mrzed001
Voice of reason
Hi !
I am planning a grid-tie and an UPS system.
- The grid-tie 5kW, 15 panel 350W serial (all 40Voc ... so together 600V) with Fronius or SolarEdge or other utility allowed inverter. (no hybrid inverter allowed)
- UPS with MPP Solar inverter and 16x LiFePO4 cells 3,2V 280Ah (48V)
- SCC that can handle high PV like the grid-tie inverter and charge the battery with it
If a blackout happens the grid-tie inverter stops working.
I plan to switch the PV power line from the grid-tie inverter to SCC (manually).
So I am searching for a SCC which can handle the high PV power and charge the 48V battery with it
And if battery is full then stops charging it.
( I could use an MPP Hybrid MPI 5kW inverter to charge the battery OffGrid mode (its MPPT can handle the high PV volt), but it is too expensive for this simple task )
Any suggestions ?
Thanks
Any suggestions ?
Thanks
