Sojourner1
Itinerant
All 12 vdc loads are seen on the GBS display, fridge & interior fans, furnace, electric awning, slides, bigfoot levelers, water pump, misc 12v lights all register on the display when in use.
For what its worth, these are the setting I've been using for the past 5 years. Magnum 3000w hybrid inverter/ charger, Magnum PT100 SCC, ME-ARC50. The scc follows the exact settings that the inverter/ charge is set for. When on occasion I use either the Honda eu2200i or a eu2000i generator I'll set incoming loadshare to 15a and charge at 100a.
If on shore power I'll turn off the charger (on the inverter/ charger) and use only solar to top off the batteries and then float , depending on the furnace run time during the night nighly consumption is 25-35ah or 5-7% DOD.
Thanks for the battery charging settings.The following parameters are for programming the ME-ARC Version 4 advanced control.
Setup 02B LBCO Setting: Volts = 12.0
Setup 03C Battery Type: = Custom
Set Absorb Volts: = 14.1v or 14.2v (depending on season)
Set Float Volts: = 13.6
Set EQ Volts: = 14.1
Set EQ Done Time: = 0.1
Setup 03D Absorb Done Time: = 0.1 (minimum)
Setup 03E Max Charge Rate: = 100%
Setup 03G Final Charge Stage: = Float
This keeps me in the manufactures (BB) suggested charging range. 14.2 v being the lowest Bulk/Boost charge BB specifies and 13.8 v being the highest float charge BB specifies. Thereby operating the battery in the 13.8 to 14.2 bandwidth when the sun is plentiful. Meets my desire to operate the BB batteries in a narrow bandwidth to optimize SOC at the end of the solar day, and keeping the Boost voltage as low as possible to extend the life of the batteries-I'll be using a Victron smart SCC, will use the settings V absorb 14.2, V float 13.8, and a return from float to Boost as close to 13.8 as possible.
These settings are also within the BB recommendations for charging the batteries I have. Buy allowing a low float from the inverter/charger, the top end of the battery charge will be completed by the SCC in the sunlight. Inv/Charge will only be done when shore power is available or when the sun does not keep up with my battery use and a generator is required.-I'll set the Magnum Hybrid MHS inverter/charger to absorb 14.2 v, float 13.2v so the SCC will perform the battery top off maintain function as long as the solar is good.
BB CEO Dennis is quite adamant about charging the BB bats to 14.2-14.6 v and holding them there for 15-20 minutes per battery string to top balance the batteries with the BMS BB has provided in the 100AH 12V battery. I believe this is a passive top balance. Then allow the batteries to float at 13.2 with the Magnum in the dark or 13.8 with the SCC if the sun is out.-Considering an occasional (maybe once weekly when boon docking) SCC or Magnum 14.4v equalize charge to 14.6v maintained for 15-20 minutes to force a BB cell top balance with the BB BMS.
are you on hookups? In my opinion 13.8v float is still a little high even in an daily use, 13.6v is plenty.Then allow the batteries to float at 13.2 with the Magnum in the dark or 13.8 with the SCC if the sun is out.
We both have LiFePO4 batteries.are you on hookups? In my opinion 13.8v float is still a little high even in an daily use, 13.6v is plenty.
You may find this info a bit entrusting.Nope, the generic mppt Genasun for LFP is hard coded at 14.2v. If one has a more specialized need then they can simply custom order for a different voltage limit. Just a CC/CV. Nothing to set. Just hook panel and battery up properly and done. No other concerns.
They don't offer large-current controllers, although I suppose if one was in love with them, you could do multiples on a single battery ... but errr.. yeah that's a different decision to make.
Normals - heh, no that means people more interested in camping or whatever with their batteries than trying to figure out "Wait, you guys spent 5 years arguing about something called top-balancing? Isn't that vertigo? You guys need to go to the doctor!"
