esse elle gee
- Nov 7, 2021
- 3
I have a newly installed SW4024 with a Xanbus connected System Control Panel (SCP) and a MPPT60 CC.
-The system works well, except that when simultaneously charging and inverting, the SCP displays a battery current that randomly changes and is incorrect by up to 4 amps ( I verified with a meter that the system works well, it's only the SCP displayed battery current that is wrong).
- All 3 units have up-to-date f/w.
-The A/C load display jumps around as well, even though the actual A/C load is dead stable.
When I disable the inverter, the SCP displayed battery current is 100% correct (ie matches the charge controller).
-There are no logged faults or warnings.
Troubleshooting so far:
-triple checked wiring
-swapped out batteries
-swapped out inverter
Any ideas what could be wrong?
