Thank you for the picture! That is a perfect visual illustration of talking to Schneider tech support.... after a one hour hold listening to the dadada ding ding ding dadada ding ding ding "music"
What is the DC or Battery Voltage Difference show in Insight Home between the Inverter and the MPPT?Here is my MPPT charger setting
And here is the battery setting on the MPPT
So far, this has been working great. I am not sure if the -70 is the final number, but I have tried 0 and no output at all. I tried small numbers like -10 and that produced a tiny output. So by experimenting, -70 seems to work best, but I still need to observe it under various light conditions.
There are various voltage across the system. First The battery recommended float voltage is 54.4. Measured with a Fluke digital voltmeter at the dc bus is exactly as the battery and exactly as the battery integrated display. At the mppt's it is 0.1 volt above; 54.5. At the Inverter display in the gateway it is 0.4 volt above: 54.8 v, SCP shows 0.2 v above. That is why i setup the charger at 54.6, when the charge is finished it display 54.8 in the gateway, so it is really 54.4 v. spot on.What is the DC or Battery Voltage Difference show in Insight Home between the Inverter and the MPPT?
Thanks for you time. My system is in open loop, so no soc. I am fighting with the Fortress Power people because their modbus interface with the gateway is always showing positive current no matter if charging or discharging. soi disconnect the interface and reset the gateway to factory and started in open loop. Also my battery float setting recommended is 54.4 v, but the mppt shows a bit more, about 0.1 volt above.I do not use the charger on the XW Pro so the "Cold" setting makes no difference. Also, I assume that for your battery the float voltage is specified as 54.6 ?? For mine, it is 54 and so that is the value I use. My Grid support SOC is lower at 95% instead of the 99% you have. In my case with 54 V for the battery value, the SOC at 99% would keep it from exporting.
Sadly, I dont think there is a procedure to calibrate. Workaroud would be what you already did.There are various voltage across the system. First The battery recommended float voltage is 54.4. Measured with a Fluke digital voltmeter at the dc bus is exactly as the battery and exactly as the battery integrated display. At the mppt's it is 0.1 volt above; 54.5. At the Inverter display in the gateway it is 0.4 volt above: 54.8 v, SCP shows 0.2 v above. That is why i setup the charger at 54.6, when the charge is finished it display 54.8 in the gateway, so it is really 54.4 v. spot on.
Is there any procedure to calibrate those suckers? Thanks
You can keep using the latest firmware and leave the inverter setup as Lithium-Ion. Just need to play around with the mppt settings to get the most out of them.Thanks for the input. For your recommendation i will have to change the inverter battery type to Custom. Easy Peasy. But first I will try to re-flash the previous firmware 1.11.01 build 49 to the inverter. I have not tested selling before with this previous version bacause i was waiting for the utility to change the Meter for net-metering.
Where and how is this SoC determined?My Grid support SOC is lower at 95% instead of the 99% you have. I
I heard today from Schneider that they will release within a month the firmware for MPPT close loop with batteries.What I hope, and I hope Schneider is listening, is that they will update the firmware on the MPPT to be able to do this all in a coordinated manner. The big benefit for the MPPT firmware change would be that it could know what the actual current is to the battery and what it is to the Inverter... this could eliminate a lot of this nonsense.
The Wi-Fi Acces Point is on all the time unless its disabled.I wish I had thought to write to them earlier and ask for when the Insight is connected by ethernet cable, that it shuts off its wifi . Mine seems to always be on even though it is hard line Ethernet cable connected.
Do you folks have an email address that you use to communicate with Schneider? I do not see it online.
When I call them, it is a crap shoot if they will even stay on the line 2 minutes before disconnecting me.
In fact, I have never been able to speak to a human so far.
Dont get me wrong, I have no big issues with their equipment, it is the best I have owned so far.
Yeah, definitely a fluke/bug. I have experienced it.Thanks, but I have had the Access point off since I set it up and still I see it showing on my Dell Pc from time to time.
Must be a fluke.
I just did the update to 1.18 and lose wifi, access point, everything. Had to remove and do a factory reset. It said something like that in the fw readme. But now i dont get internet access. Dont know what else to do. Gracias ! I did reset my lan access point and my switch also, just to be sure but nothingYeah, definitely a fluke/bug. I have experienced it.
Just now i did a firmware update to 1.18 and after it was finished the Access point was on again after it was set to off before the update.
What do you mean you "lose wifi" and "don't get internet access" ?
Do you have the IP for the Insight to log in from your local network?
If you did a factory reset, all your log in and password information is lost. I'm pretty sure you've got to start fresh and connected your laptop to the access point created by the Insight.
A similar thing happened to me, but I was able to connect using the InsightHome Wi-Fi AP. From there i had to configure again the network settings so it was able to connect to my Wi-Fi network.I just did the update to 1.18 and lose wifi, access point, everything. Had to remove and do a factory reset. It said something like that in the fw readme. But now i dont get internet access. Dont know what else to do. Gracias ! I did reset my lan access point and my switch also, just to be sure but nothing
