Bluedog225
Texas
- Nov 18, 2019
- 2,909
On the bright side, I bet Signature Solar will have a pretty good handle on this issue going forward.
PM sent.Sorry about the delay, I've been out of the office and just returned. PM me your info and I'll see what I can find out.
Called they are out of stock and will not have any until the first week of February.The support guys would probably welcome that particular call. Something tells me it might be an easy fix.
Really? so I can hook up the other 5? I didn’t mention to her that I don’t have a GroWatt so maybe that’s the confusion. I just assumed the batteries talked with each other to balance correctly.Without a Growatt inverter or a laptop not sure what you will hook the RS485 cables too. My understanding is the batteries don't talk to each other, but can be configured to be polled thru the RS485 by compatible inverters. Right now that's just Growatt inverters.
I took all the RS485 cat5 cable jumpers off mine. I hooked my laptop to each of them to check the BMS and voltages, but there's nothing to set, just monitor if you want.
Tried charging just the 5 nope. Tried charging them one at a time nope. The reason the one has more charge is because last night I wanted to see if my Honda eu would power the charger so I let is run for about 5 min. And it charged fine.I wouldn't think the slightly higher voltage from your original battery would cause them to not charge, but maybe it's a protection "no charge allowed until battery voltage matches". I would power up with new matching voltage batteries and see how they charge without original higher voltage battery. If they take charge, charge them to match the original and then turn it on and see if they are all happy. Just guessing here, never had that happen.
I'm Thinking now I should have just bought AGM’s And saved about 6k or just bought 7 more Chins batteries. up until tonight I’ve been living off a single 12.8v 300ah Chins with a Reliable inverter from Amazon for the last 3 months now. Powering my entire house with not a single problem other then not enough sun.@merritt2828 is right if you had the USB to RS485 converter and a cat 5 cable to plug into them, you might learn what the fault is. I have no idea, but those LifePower4 batteries sure seem to have a flaky or temperamental BMS in them...
Your a freaking Genius! I didn’t even think of that. They have been in my cargo since I picked them up. Other then the one. I brought it into to the utility shed the day I brought them home. The shed is fully insulated and I have been running the heat while I work on the Magnum and the rack.Have the batteries been stored outside?Any chance the internal temp of the batteries could be below 0 degrees C? I don't think it's a current problem because the good battery in parallel should buffer current flow.
And of course, the electrical solution to every every problem, tried hitting the reset button?
We ran out for a minute. Give us a call and we can send some out for you.Well I have something to bitch about now.
how many other people didn’t get the RS485 communication cables with their batteries?
Hope this works! Keep us posted!Your a freaking Genius! I didn’t even think of that. They have been in my cargo since I picked them up. Other then the one. I brought it into to the utility shed the day I brought them home. The shed is fully insulated and I have been running the heat while I work on the Magnum and the rack.
I totally forgot about the low temp cut off! All my systems in the past have been small lead acid. To me it wasn’t that cold today. but last night I’d did get down to the twenty‘s my son said.
the shed is at 45 right now and shouldn’t get colder the 40 before morning. I’ll try it again in the morning and see what happens.
I know this is the problem. Thank you so much!
41 deg in the shed and all 6 batteries are charging as the are supposed to.Hope this works! Keep us posted!
