Well its total speculation by niktak that the 6848 could run at 10Kw continuous just with more fans. At a certain point the heat generated is too much for any number of fans and it has to ramp down output. Just like any inverter. The idea that Schneider deliberately rated the 6848 as a 6.8kW inverter simply to produce an impressive surge graph versus labelling it as a10kW seems doubtful. It's just a happy byproduct of robust system design.
Sure its deliberate, everything in product design is tradeoffs, if you add a water cooling system and used Gan or Sic transistors or any number of more expensive designs your continuous and surge capabilities can go up, thats why a inverter in a EV can do hundreds of KW and massive surge and is a little HF design.
Maybe before long we will see water cooled whole home inverters and have debates over air vs water cooling for home backup like the generator guys do.
More or less active air cooling is a design choice. With the big HF designs you see the smaller power transformer and more / bigger power transistors bonded to a large aluminum heatsink on the outside with fans blowing over it for outdoor rated use. The LF's tend to have fans blowing over the fets and large transformer on the interior of the case, seems more difficult to do a direct outdoor rated design.
We do see many HF inverter uses having to resort to soft starts etc to get their big AC compressor loads etc started.
Seems to me people use soft starts if possible for inverter driven systems unless complete overkill, especially if it you air conditioner thats starting / stopping all the time. An LF inverters FETs are still taking the surge, the big transformer has no issue but it's the FETs you worry about, go watch the Victron video describing overload conditions, they never mention the transformer once and continually talk about the FET bank.
First time I used a soft start was with my last RV where I added a 3000w Magnum LF to run the whole thing. It would overload sometimes starting the 15kbtu A/C. Even if your LF inverter can handle the surge its much better for its FET longevity to have soft starts or VFD unless its just a once in a while thing like starting a saw or something either that or way over build.
First thing I did when planning for my whole home solar install was put a soft start in my 5 ton a/c regardless of which inverter was going to drive it, better for the a/c compressor too. I won't buy a new A/C system unless its variable speed if I can help it, which is by nature soft start. Same probably for next well pump all though that a much smaller motor.
I would agree that there's generally choices in the market, "conservatively rated" LF units, or HF units with more "optimistic" numbers. For those lured in by big numbers the eg 18kpv and flexboss 21 etc sound very impressive. Ultimately both are limited to 12kW inverter output from batteries, no matter how loud or fast the fans spin.
12k continuous vs 12k surge for the XW pro...
Still interested to know what the price of an equivalent XW pro system would cost back when it was being made, because thats what it comes down to. Looks like some great deals on that equipment right now I guess due to being discontinued, but if your comparing HF to LF and a 6kw with 4x start surge is the same as a 12kw HF with 2x start surge well how much does it matter that one has a 4:1 surge ratio and the other a 2:1? What am I getting per dollar is what I am looking at and what loads do I have to support and those decisions are based on much more than just inverter topology.
