Philip53
10.4kw DIY Home Solar Sprinter Van DIY Victron
As I have said in previous posts, I was continuing to work on my 'Pro' settings to reduce sell cycling & such. Unfortunately, I have had very few sunny days where I could get repetitive results from my settings. I really appreciate everyone's input in this and other similar threads, but I think I am done at this time - at least for a while. Here is a screenshot of my best day yet. Also I have listed some other data from this day, along with settings for my CC's. I have one XW6848 Pro, 3 - 100/50 CC's, 430ah lithium battery bank, 10.4kw PV.
This is a hybrid set up, grid connected and I am aiming for as high a sell to grid as possible. I have the inverter set for max sell amps. The inverter powers my home critical loads through a sub panel, with about an 800 watt load during most of the day. Routinely, during most of the day, I see in slight excess of 6kw selling back to the grid (including of course, the current critical loads).
EDIT: I see that I neglected in include here that my Grid Support Voltage is set at 53.6v. This setting guarantees that the battery voltage never reaches the 55.5 volts that the CC's are set for, but these settings do allow the CC's to continue to operate at their max output watts (dependent upon sun irradiance, of course).
Battery Summary chart below.
Total PV produced 53kwh
Battery chg. 1.9kwh
Battery discharge .268kwh
Batt chg/PV output 3.6% (cycled 3.6% PV production through battery bank - mostly, I think to bring up resting batt voltage to CC charging specs, very little sell cycling through the day)
CC settings
Bulk 55.5v
Absorb 55.5v
Float 55.5v
Resting battery voltage 53.55 (average)
There was a tremendous amount of trial and error to arrive at what appears to be 'random' settings. If the CC settings were any less, the output from the solar panels would be reduced from full capacity. I had adjusted the settings to allow as much charge time as possible through the day, with float only happening on some days near the end of solar radiance. The 55.5v float still allowed some some current to be sold to grid.
This day was sunny all day, no clouds.
Battery chg. 1.9kwh
CC settings
Bulk 55.5v
Absorb 55.5v
Float 55.5v
