Ceefiveceefive
- Sep 28, 2019
- 93
I seen a few other folks referencing these.
Would these work well in an RV with high power usage?
I found a question that was asked on Amazon and answered by the seller:
Does the BMS provide a protection against overcharge ?
Yes.BMS will provide charge and discharge protection and short circuit protection.
Kepler Industrial Co., Ltd. Seller
Amazon question about Scream Power BMS
I can’t open the battery without destroying the plastic case. It seems to be good quality plastic made out of two pieces. The lid of the box appears to be glued on, but it’s almost like plastic - it’s not something you could pull apart or heat with a hair dryer and pry open.
The seller has never advertised a low-temp cut-off for charging. Based on that and the manual they sent with my last battery, it’s safe to say it does not have low-temp cut-off.
So this would limit some use cases. Not sure if someone who is resourceful and can add a similar feature outside the battery (without having to saw the case apart and replace the BMS).
And maybe in the US the price isn’t as compelling. But buying the battery through Amazon (for me) included shipping, duty, and sales taxes. So the price they list is the out the door price.
I am concerned about their generic documentation and sticker on all their batteries. I hope they stick around, but they do have the feel of a company that could disappear. Definitely not the same comfort level as a Renogy or Battle Born!
Question:
Please verify BMS has / low temperature protection.
Answer:
Yes, low temperature protection is standard for a BMS this size.
By Michael See on February 15, 2021
I opened mine. The seller showed me how in response to a warranty request I have pending. Battery worked well for me for the first few months, but I'm not sure it achieved its rated capacity, and it failed after 3 months of use. See my post here: https://diysolarforum.com/threads/scream-power-lifepo4-battery-wont-hold-above-14v-charge.22227/I found a question that was asked on Amazon and answered by the seller:
Did you ever figure out the issue? I have 3 of these batteries doing the same, not charging over 13.2v or so. Any help would be appreciated!I opened mine. The seller showed me how in response to a warranty request I have pending. Battery worked well for me for the first few months, but I'm not sure it achieved its rated capacity, and it failed after 3 months of use. See my post here: https://diysolarforum.com/threads/scream-power-lifepo4-battery-wont-hold-above-14v-charge.22227/
To the seller's credit they've been prompt in responding and are willing to send me parts to fix the battery. So we'll see what happens.
