chrisski
Solar Boondocker
- Aug 14, 2020
- 5,189
What would you use to take a low amperage DC 24 volt line and split it into three different outputs?
I am looking to split a 8 amp line off a fuse box to three different outputs. Each of these three lines would be sent to a DC low amp light.
I’m looking for something professional.
I looked at power distribution bus bars, but the studs are way too thick.
Terminal blocks look good, but the ones I found don’t split power, but are insulated from the next set.
I looked at the hardware store and after I bought a Gangbox, and other hardware from the aisle, it’s more pricey than I think.
A wago connector with 4 conductors would work, but I’d like to be able to mount it.
This is probably an easy item that I just entered the wrong terms in my searches.
