captainrivet
- Jan 27, 2020
- 73
Why you need to keep space and openings in the enclosure to breath for the cells?
I see that in many build threads mentioned
In drop ins (saw in many cut opens there is no space till 1-3cm) they are sealed and sometimes even encapsulated in glue or resin and they just have a little opening for pressure equalization or a valve. This is to minimize vibrations, corrosion and oxidation on all parts.
I have 3p4S Lishen cells.why the eve or lishen or alike build prismatic cells should be different in that matter?
I plan to build a box of nylon boards, due to space constrains I have 3cm between top of the cells and top of the box.
i also plan seal the battery enclosure and just leave two openings where the main battery cables come out as it is used in marine environment on a cat.
