sunnysea
- May 29, 2022
- 3
Hello there!
First this forum has been an amazing mine of information and I am so grateful for all I am learning here.
I built a small backyard shed this summer with the goal of making a small off grid solar system with it. I finally have a blueprint ready to share and could use some second opinions on it. I am sure I am missing a few things. I am especially not too sure about:
What I plan on doing with the system is described on the right side of the array (on the blue print). Mostly low voltage landscaping lighting. I went with 24v instead of 12v for the battery and hope it is not a mistake! It should be fine with the solar array but maybe not as efficient on cloudy days? I'll also likely need a buck converter or the like for driving a relay board (that I'll likely build myself).
Here is the blueprint and I attached the full PDF with clickable links:
- The grounding (and if grounding the negative battery terminal is fine), I still preemptively drove in the ground a 8ft grounding rod next to the shed (it's really far away from my home's grounding rod)
- All the wire gauge and fuse (although I used this post for help)
