So my last battery was a Battleborn, so bolted through to hold the lugs on, just used a drop of Loctite blue and tightened down, good to go.
I've got a LiTime now, where the battery terminals are a bolt that I screw down through the lugs into the terminal. I'm wanting to use some Locktite Blue again, should that be fine? Just be careful to avoid getting any on the top of the terminal where the lug will sit?
