No-one-&-Not-Important
From Nebulae to Neighbors: One Photon at time!
I'm just seeing and catching up on this thread. @No-one-&-Not-Important sounds like we have a very near same setup....2x 12000xps, 4x eg4 wallmounts, a pallet of hyperion 400w bifacials... Nice! (I'm loving the heck out of my system and it's overkill for me, but should last a very long time....and I've been grid free for over 50 days now. I would suggest (cause i'm a nerdy engineer too) getting a Sense power monitor or similar as it was eyeopening to me, my loads, daily usage, etc.....and it will likely help you to find places to become more energy efficient.
I am skeptical about the heat pump dryer (Reddit posts everywhere how it's fine at first and then "craps" out over time, with all kinds of issues (smell, condensation accumulating on the exchange coils, etc...); even to the point where LG basically pulled out on some of their models; Samsung recently did the same; Miele is not only too small but even more expensive; why would you even get one?!?). BUT I'm DEFINITELY in for the heat pump water heater.I saw @green-river suggest a heat pump dryer which would be more efficient, but take a good bit longer. Heater in my electric dryer is like a 5kw load when its on, so no issues on my end. Now, I do love my heat pump water heater and I have it scheduled to be on only during solar hours...so free hot water (basically).
You can use AC just to charge batteries (based on SOC or voltage for closed vs open loop comms) while still inverting (tested this); and inverter should switch to grid bypass/charge if batteries get low enough (never tested this). See https://diysolarforum.com/threads/12000xp-low-soc-settings-help.97272/#post-1323757
Are you saying that the inverter can deliver 100A as AC Output? How did you manage this? I could not find this. Which is why I am getting two inverters. Each can only AC output 50A. Or did I misunderstand your comment?I wired each inverter to handle 100A from grid and to deliver 100A output since it's supposed to be able to bypass 100A from grid through it to loads. Manuals and all were a bit confusing on this...
Watch your torque specs in the 12000xp manual; I've email EG4 folks about this with no response that they need to look at these and correct them before someone breaks something. The CHNT breakers call for 31in-lbs. Also, verify the torque on the inverter connections where you can (battery terminals, the ground and neutral bar); I found the inverter neutral barely snug on one of my units and neither torqued anywhere near what Luxpower or EG4 called for in their manuals. The Luxpower SNA 12k is our equivelent, btw; and Eddie/Edwin on here is the US Lux rep too.
Why did you bring MC4 connectors down your conduit? Easier to fish or you might expand your array later, or just wanted to be done quickly & will strip later, etc...? BTW, that's one "fat" conduit down your pole! I'd never pass inspection with a non-metal exterior conduit, incl. fill rate, in San Cautious-e, Bureacratifornia... I mean San Jose, California.
Thanks a bunch @killercarver. Good luck finishing the built and look forward to the cleanup! And BTW, "forever remodels" are real...
