Looking to make sure I am wiring my LV6548 correctly. Will be totally off-grid. Will have a generator going into the AC input to the LV6548. AC output is going to go to a breaker panel next to the LV6548. The plan is to later add a second LV6548 for 240 volt to operate a well pump, but that will be several years down the road. A 100-amp sub-panel off of this panel to the cabin.
I will be doing this in stages. First stage will be to get the 2 EG4 48volt batteries wired into the LV6548. Add the generator as the AC input.
Later in the Fall, I hope to have the solar panels ready to wire into the LV6548. The generator will be used to charge the batteries until then.
Here is the picture of what I am looking to make sure is correct: I will probably also add a disconnect to the positive 4 AWG from batteries.
- THANK YOU!!
- THANK YOU!!
