or blow it up!!!A 24 volt panel is an interesting idea. That would allow for charging at the full 7 amps assuming it does not trip the voltage limit...
Can you point me to that? I haven't seen anything along those lines. Thanks. (I've seen it with Goal Zeros, not Jackerys).Also, I recall with the Jackery 500 that people were hacking in a high rate MPPT charge controller to replace the PWM version it came with. Now it is starting to make a little more sense why they were doing these modifications.
Good sleuthing! Next time you shop for panels in person, you know what to test!0.02 amps <-- This should be 5+ amps!
Can you post a pic of how your amp meter is setup when showing .02 amps?I agree it is odd that they both measure the same low current value.
Thanks!On a side note, I got feedback from Jackery that there is an automatic cut off if the 30 volt charging limit is exceeded.
If you can send a pic of the meter that would be helpful. And double check that both panels are producing ~19v still.I will give it another try tomorrow with the 10A setup (red lead on 10A and selector on "A") and see what I get.
Where is the pic of the power meter?Here are my latest findings with the solar panel testing
