Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,578
The BMS can't control anything (except disconnect) unless it has a data link to the inverter/charger. Some systems do.
But so far, all I've seen is temperature limit to cut out charge. Never a series of steps or a curve to adjust charge.
I think better EVs do regulate current (and temperature). From what I've seen of BMS and batteries for solar applications, I would say determine what max charge current is possible and set temperature limits accordingly. Then heat batteries to avoid disconnect if desired.
