Bluedog225
Texas
- Nov 18, 2019
- 2,830
Very cool. Engineer required.
400’Jeeze wells are expensive. How deep?
I actually needed this for several different reasons. One involving my perpetual motion downhill/uphill bicycle track. If anyone wants to see big jumps let me knowEngineering requires parameters/model and equation or simulator. Getting a good model is the tough part. Always easy if you assume a simple weight on a spring (ideal components.)
You could place an iPhone on the floor, drop a sandbag, record the response.
You can then predict how it would react to any given frequency, within its linear range.
For instance, that laundry machine on "spin".
Probably, Excel could be used to compute timesteps in a series of cells, then graph.
Accelerometer
Accelerometer is an app which allows you to measure acceleration in all three axes in the most beautiful and understandable way ever! • Plots realtime charts of acceleration • Option to include or remove gravity from your measurements • Export your data • Logs maximum and minimum acceleration...apps.apple.com
The container was born in 1997 same with me. It’s been sitting in hiding at a port since 2000.You folks already did so, but anything used in International shipping especially from China, fumigate for pests, small crawlies and big ones too. I got a laser imported directly from China and crawlies inside and I got them all I hope with the bug killer spray. I can imagine the ones in the containers!
Architecturally these are beautiful.You can tune the resonant frequency to taste.
Some designs have been reported to be bouncy.
I think making a composite with concrete could dampen that quite a bit. e.g. weld on screen, attach chicken wire, apply stucco.
Woah do you have a real water toilet lol?!?In no particular order.
Self explanatory other than there 3 queen beds. One in up the little ladder. Under that one down the hall, there is another the "minecraft" cave and then master bed in the back.
Above that first queen bed are two twin beds.
All craigslist free or cheap stuff including all appliances. Modified if needed and reconditioned as best as possible.
These are "under construction" photos so there is still punch list stuff (trim, shelves etc) yet to be installed.
View attachment 98053View attachment 98061View attachment 98056View attachment 98057View attachment 98058View attachment 98059View attachment 98060
You must be reading my “to do” list. Im painting the roof with the elastomeric this weekend. I also slapped some exterior paint onIt could happen but my container was pretty clean. Big, empty box. No place for bugs to hide. Maybe underneath.
Jack it up at an incline and hose it out. Scrub with dawn. Let dry. Put a couple of coats of shellac on the wood floor.
Hit the outside rust spots with cold galvanize every year.
Scrub the roof with dawn. Paint with elastomeric cool roof (Lowes). Two coats. Makes a big diff.
Hit mine with zep degreaser, pressure wash then phosphate.Careful. Not only is it slick, but it’s so long and narrow, every step is an opportunity to walk off the edge. And a big, thick roller can get in between the ridges better.
I scrubbed my top down with a floor brush/dawn. 10 years later, no sign of peeling.
Yup! With a hot water butt sprayer top.Woah do you have a real water toilet lol?!?
That’s awesome I’m pretty excited to get it doneCareful. Not only is it slick, but it’s so long and narrow, every step is an opportunity to walk off the edge. And a big, thick roller can get in between the ridges better.
I’m positive mines going toHit mine with zep degreaser, pressure wash then phosphate.
It will probably peel.
Boy you’re living large. I’ve had the pleasure of using one of those once. I left the restroom with a huge smile.Yup! With a hot water butt sprayer top.
Don't like pooping in holes.
I was being facetious. It shouldn't.I’m positive mines going to
Peel. When? Is the question I have
Okay awesome lolI was being facetious. It shouldn't.
