NO LONGER AVAILABLE Selling 8 Lishen 272ah and 8 Eve 280ah Lifepo4 cells
If it's not too much work, can you post up dimensions of two different cells? To the nearest quarter inch is fine, unless you want to do metric, that is fine as well.
Here is what I found online. Both the Lishen and Eve cells are the same size. However at least on mine, the Lishen cell terminals set a little higher than the Eve cells.
