I found 1.8 Ohms resisters as I just described 20 miles from me on Ebay so I bought a open bag of 66 resistors for $50.00 USD I got all excited about my great find and went to the online calculator I entered .18 Ohms and 3 volts. Later that night went to check the order and realized my mistake but didn't want to cancel the order, Now I'm thinking I can put them in series to get some of the load that I need.
Well if you put 10 of them in // you'll have the 180 mOhm resistor you wanted
I can also use switched, single resistors to fine tune the load. Does this make sense?
Yep, more resistors = more power discharging the cell, super simple.
Years ago I build a 12 volt load bank from a 120 vac 1200 watt space heater by cutting the element into 10 equal links to make 12 volt heat elements. I may have to find a cheap used heater and do the same but cut them into 40 equal lengths for 3 volt elements. As I remember, it is was a pain to make a good connection to ring terminals.
I actually had the exact same idea... easy way to connect them is to pinch between two nuts on a bolt or threaded rods as you can't solder them (even if you could they would desolder themselves when getting hot anyway...)
One other thing who works well, easy too build and cheap, is to use steel wire (or even better stainless steel) immersed in a water bucket. You can dump incredible amounts of energy into it as water is very effective at cooling the wire and it'll boil (and it takes lots of energy to boil water) so you can't really overload it (well you always can but I think it's plenty good for what you want to do)
Here is the link to the resistors I bought. Might have to scroll down a bit. https://www.ebay.com/itm/66-Sei-Sta...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Ah... that's why I asked what resistors you used: the aluminium body ones can't handle more than 1/3 (or even 1/4, can't remember exactly) of their power rating withouth being mounted on an heatsink. Ideally you want to use the ceramic because they can handle their rating in free air (they'll be extremely hot tho, be careful), like those:
But in general try to stay under 1/2 or 2/3 at most of the rating of any resistor, they'll run much cooler and have a longer life with less risks of burning you
